Auto: Opel Calibra/Omega C25XE-Y32SE
Geschrieben: 06.09.2020 - 23:50 |
Happy that you have been able to sort the gear linkage
Did you also blocked the gearbox with the screwdriver as i do not see the picture? |
Auto: calibra 2.5
Geschrieben: 07.09.2020 - 06:08 |
I just used the screwdriver to fix it to place when my friend adjusted it under the car. not the L key😁 |
Auto: calibra 2.5
Geschrieben: 16.09.2020 - 20:59 |
It was time to change the fuel pump because there were problems with starting.Fuel pump lid is quite rusty.I have to check maybe there is a change to use another car lid.Right now we put a rust stop on until we find another lid,because they dont make it to calibra anymore.
I also made a video how to change a Calibra Fuel Pump.
https://youtu.be/qbKnBwk1Kp4 |
Auto: calibra 2.5
Geschrieben: 01.11.2020 - 17:55 |
Its been a while since is wrote.
Calibra has still starting problems.
It wont start everytime.So my friend put the diagnostics on and no fault came out.
After that he checked fuel pressure and one problem came out.
Fuel preassure regulator was faulty.So i bought new one.
After that another problem started.Sometimes it wont start after 10 times when i try.
Friends said that maybe its fuel pump relay.So i bought this one new also
I changed it and it got a little better but still there is a problem when there is a damp weather outside.
Here are couple of pictures.
Can anyone suggest a good online share website where i can upload new pictures and when i show them here
then pictures wont be huge size.In few days all my old pictures
will be gone from here because the service provider will be closed.  |
Dateiname: | 1.jpg |
Dateigröße: |
130.79 KB |
Vollbildaufrufe: |
1 |
Dateiname: | 2.jpg |
Dateigröße: |
174.04 KB |
Vollbildaufrufe: |
0 |
Dateiname: | 3.jpg |
Dateigröße: |
138.33 KB |
Vollbildaufrufe: |
0 |
Dateiname: | 4.jpg |
After change fuel pressure stays at 3 bar.Before it just falled down. |
Dateigröße: |
102.46 KB |
Vollbildaufrufe: |
1 |
Dateiname: | 5.jpg |
Couple of pictures about the relay. |
Dateigröße: |
131.76 KB |
Vollbildaufrufe: |
0 |
Dateiname: | 6.jpg |
Dateigröße: |
100.47 KB |
Vollbildaufrufe: |
0 |
Dateiname: | 7.jpg |
Also cleaned drivers door switch and got it working again. |
Dateigröße: |
81.69 KB |
Vollbildaufrufe: |
0 |
Dateiname: | 8.jpg |
Also Santa brought spare rear springs :D |
Dateigröße: |
120.6 KB |
Vollbildaufrufe: |
1 |
Dateiname: | 9.jpg |
Also can anyone tell where can i find left and right not damaged side plastic trims |
Dateigröße: |
111.45 KB |
Vollbildaufrufe: |
2 |
_________________ meisner
Geschrieben: 01.11.2020 - 22:07 |
Auto: calibra 2.5
Geschrieben: 01.11.2020 - 22:15 |
Matze thank you for the info and many thanks about saving my old pictures.At least then history is safe😁Tommorow i will try to put pictures on my last post also. |
Geschrieben: 01.11.2020 - 22:21 |
Auto: calibra 2.5
Geschrieben: 02.11.2020 - 07:21 |
There are few days left before these pictures are gone,so you have time🙂Matze i have problems with that photo site.I uploaded photos there but when i try to look then its just loading and loading.Internet connection is 44mb per sek so its good. |
Geschrieben: 03.11.2020 - 16:01 |
Geschrieben: 03.11.2020 - 16:25 |
Hi plenty of door strips here on brakeyards in Spain 😉
meisner hat folgendes geschrieben: |
Auto: calibra 2.5
Geschrieben: 05.11.2020 - 20:18 |
I didint like that the center console heating part was dark,so i took the big job ahead and I dont want to do it anymore.😁
Before and After |
Dateigröße: |
162.61 KB |
Vollbildaufrufe: |
1 |
Dateigröße: |
104.72 KB |
Vollbildaufrufe: |
4 |
Dateigröße: |
102.48 KB |
Vollbildaufrufe: |
6 |
_________________ meisner |
Geschrieben: 05.11.2020 - 21:05 |
Fixing this thing can be a real pain in the ass did it several times. Was not funny
Btw: why don't you upload your pictures here on our site
Regards
Geschrieben: 05.11.2020 - 21:07 |
Auto: calibra 2.5
Geschrieben: 05.11.2020 - 21:23 |
Matze (05.11.20) dankte meisner für diesen Beitrag!
Auto: calibra 2.5
Geschrieben: 16.11.2020 - 16:59 |
Does anyone has or knows where can i get new blank key with opel logo and bulb place.Thats my primary key but like you see its broken. |
Dateiname: | 34C68357-2A23-4AC4-B0C3-B03499A78A31.jpeg |
Dateigröße: |
2.84 MB |
Vollbildaufrufe: |
1 |
