Insgesamt 22251 registriert!
Gäste Online: 596
Insgesamt: 600 Fans!
Calibra-Team.de :: Thema anzeigen - Opel Calibra Keke Rosberg V6 125 kw MY 1997
Danke-Klicks: 118
Beitrag: 759156 Geschrieben: 16.11.2020 - 23:47 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
meisner hat folgendes geschrieben:
Does anyone has or knows where can i get new blank key with opel logo and bulb place.Thats my primary key but like you see its broken.
This key blank should fit you,
is the "H" series.
LINK(Werbung)
You may be able to take the lid and logo from your old key.
There is nothing more available at Opel.
Maybe in your home country, then try this number:
90512043
Kind Regards
meisner
Auto: calibra 2.5
Beitrag: 759160 Geschrieben: 17.11.2020 - 18:40 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
I wrote to the seller to get a picture from inside.Lets if it fits.I went to my local key makers and they only got the version where the chip goes on top and thats it.No keys that has the bulb place.
I just got the answer that this key havent got place for the bulb.
It took lot of time to search but i found a key from aliexress and thats the same in the
inside as calibra original key and it comes with opel logo.I will add that link here if someone else want to restore the original key.
https://a.aliexpress.com/_mNhosnT
meisner
Auto: calibra 2.5
Beitrag: 759237 Geschrieben: 25.11.2020 - 22:07 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
Finaly it was time to change the old cambelt what was 11 years old and 100000 km driven.
A little video about it also.
https://www.youtube.com/watch?v=05pCr7u42u8&t=350s
meisner
Auto: calibra 2.5
Beitrag: 759325 Geschrieben: 07.12.2020 - 22:12 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
I made a tutorial type video how to change Calibra and Vectra A Dashboard bulbes so you guys who have these oldtimers could learn.
https://youtu.be/fV-iNggXCIw
DTM 95
Auto: Opel / Ford / Fiat Calibra V6 / Escort MK 4 Cabrio 1,6i XR3i / Barchetta 1,6
Beitrag: 759458 Geschrieben: 23.12.2020 - 14:25 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
Kann mir mal jemand bitte helfen?
Da ist ein Momo Lenkrad drinnen und das Auto musste ja einen Airbag haben. Gibt es dieses Lenkrad oder ein ähnliches mit Airbag um das Originale das ich drinnen habe, gegen ein schönes auswechseln zu können?
Zum anderen da sind ja Zeichen an den Türen, ich gehe mal davon aus, dass diese Original bei der Last Edition waren. Kann mich mal bitte jemand aufklären ob das genau so Original war und welche Zeichen das waren bzw gehören die zur Rosberg Edition?
Mein Motto, ich lebe jetzt und jetzt kann ich mir meine Wünsche leisten und erfülle mir die.
Daher niemals was einem wichtig ist, auf die lange Bank schieben. Denn es könnte auch mal zu spät sein.
meisner
Auto: calibra 2.5
Beitrag: 759459 Geschrieben: 23.12.2020 - 15:01 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
Hey DTM 95.
This steering wheel on my car is an aftermarket one.
I know that my friends car has a momo steering with an airbag that is correct for the MOT.I dont have a better picture but i hope that helps.
 Dateiname: 7D0A9DAE-FFAA-4600-800D-909126804678.jpeg
 Dateigröße:  63.87 KB
DTM 95
Beitrag: 759460 Geschrieben: 23.12.2020 - 15:06 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
Thanks for the answer.
Is there a name for the momo and the hub?
Because in Germany you don't get an aftermarket with an airbag and you don't get it carried out or you have to remove the entire dashboard to also remove the passenger airbag.
Which one is inside now because the other picture is completely different?
How about the other question or the emblems?
Beitrag: 759462 Geschrieben: 23.12.2020 - 17:50 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
Die einzigen Modelle mit Emblemen auf den Türen waren Cliff-, DTM und Keke-Rosberg-Edition. Außerdem alle 4x4 Calibra. Ein Nachrüstlenkrad mit Airbag gibt es in Deutschland nur von Raid. Die Modelle heißen Silberpfeil und sind eintragungsfähig ja.gif müssen allerdings offiziell von Fachwerkstätten eingebaut werden.
DTM 95
Beitrag: 759464 Geschrieben: 23.12.2020 - 19:51 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
Danke für die Info, das schaut allerdings genauso beschissen aus wie meines, dass drinnen ist. Damit ist das Thema erledigt.
caliV6
Auto: OPEL Young X25XE
Beitrag: 759467 Geschrieben: 24.12.2020 - 12:42 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
Die YOUNG Modelle haben auch sowas wie ein Emblem an den Türen. zwinkern.gif
Beitrag: 759468 Geschrieben: 24.12.2020 - 13:38 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
Danke-Klicks: 150
Beitrag: 759473 Geschrieben: 25.12.2020 - 22:38 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
DTM 95 hat folgendes geschrieben:
Wenn du beide nebeneinander siehst, könntest du deine Meinung evtl. revidieren. Als 32er sieht das Raid klasse aus, ist von der Haptik schon ne andere Liga. Und die Fuhre lenkt sich auch besser als mit dem LKW- Dingens.
DTM 95
Beitrag: 759474 Geschrieben: 26.12.2020 - 01:32 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
ich möchte Dir ja nicht widersprechen, aber für den Preis und dann doch nur ein kompromiss, ist mir dann doch zu teuer.
Danke-Klicks: 150
Beitrag: 759475 Geschrieben: 26.12.2020 - 10:58 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
Du kannst ruhig widersprechen, ich bin verheiratet und kann damit umgehen biggrin.gif .
Deine begründete Meinung ist doch ok ja.gif .
Slusher
Danke-Klicks: 15
Auto: Calibra MV6 B308
Beitrag: 759487 Geschrieben: 27.12.2020 - 01:18 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
Auch als 32er ist das ne starke Geschmacksfrage, ich finde das RAID auch in jeglicher Ausführung hässlich, bzw absolut unpassend im Calibra Innenraum.
-Zylinder statt Kinder-
Wir hatten 420797186 Seitenklicks/Aufrufe seit unserem offiziellem Start am 10.05.2002
