Mitglieder Online: 5
Gäste Online: 409
Insgesamt: 414 Fans!
Calibra-Team.de :: Thema anzeigen - Opel Calibra Keke Rosberg V6 125 kw MY 1997
meisner
Auto: calibra 2.5
Beitrag: 757789 Geschrieben: 16.07.2020 - 08:29 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
Greetings from Estonia.
Its been over 9 years when i owned a Calibra.I had to sell my last calibra because my son was born.So it took time but here it is.
I Bought a 1997 Opel Calibra v6 Keke Rosberg Edtion number 852 of 1000 My car was made in Finland.
Keke Rosberg badges on the doors and trunk.
Irmscher 30 mm lowered springs.
Irmscher rear spoiler with brake light.
Seats with yellow stripes.
Keke Rosberg badge in the center console.
BBS 16 inch wheels.
Door openers and roof strips are in body color.
I will add a video what i made when i bought the car in 07.08.2020
https://youtu.be/0EtDawIuxMg
 Dateiname: large_29870713_FtQJ.jpg
 Dateigröße:  185.86 KB
 Dateiname: large_29870709_qsy0.jpg
 Dateigröße:  156.28 KB
 Dateiname: large_29870711_ySoe.jpg
 Dateigröße:  118.6 KB
meisner
meisner
Auto: calibra 2.5
Beitrag: 757823 Geschrieben: 18.07.2020 - 16:15 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
So i made the first wash after purchase.
Engine bay got a little cleaner.Does anyone have that peace what goes under front panel and is for ventilator pipe.
Because someone had to much brute force then the handbrake leaver is bent.
I used some tools and bent it back.Probably when it got bent then someone broke the
plastic frame what is under the leather.Instead putting some glue there he decided to put a screw though leather.
I glued the plastik together and removed the screw and its fixed.
Also the gear leaver frame was broken and leather put on wrong way.
I took it appart and glued the plastik and put the leather on right way.
I didint liked that car papers were in a envolope,Thats why i bought a opel leather
document wallet and gave it a clean and leather cream.Result is pretty good
So this time i added lot of pictures and talk,but there is are lot of thinks to do.
In september is am planing to fix the front end.
 Dateiname: large_2987071J.jpg
 Dateigröße:  127.63 KB
 Dateiname: large_29870739_tmzB.jpg
 Dateigröße:  99.26 KB
 Dateiname: large_29870741_nHn1.jpg
 Dateigröße:  107.51 KB
 Dateiname: large_29870743_ECVK.jpg
 Dateigröße:  123.81 KB
 Dateiname: large_29870745_vU5c.jpg
 Dateigröße:  79.88 KB
 Dateiname: large_29870747_4V0B.jpg
 Dateigröße:  130.53 KB
 Dateiname: large_29870749_6xUQ.jpg
 Dateigröße:  147.08 KB
 Dateiname: large_29870751_Bxc4.jpg
 Dateigröße:  133.25 KB
 Dateiname: large_29870755_1KF5.jpg
 Dateigröße:  113.61 KB
 Dateiname: large_29870757_wVxR.jpg
 Dateigröße:  55.88 KB
 Dateiname: large_29870761_P1QN.jpg
 Dateigröße:  111.41 KB
 Dateiname: large_29870765_E8jf.jpg
 Dateigröße:  120.95 KB
 Dateiname: large_29870769_7CyU.jpg
 Dateigröße:  57.55 KB
 Dateiname: large_29870773_tJI7.jpg
 Dateigröße:  73.44 KB
 Dateiname: large_29870775_Qbt3.jpg
 Dateigröße:  150.91 KB
 Dateiname: large_29870777_e2l7.jpg
 Dateigröße:  126.12 KB
 Dateiname: large_29870779_5EUi.jpg
 Dateigröße:  95.77 KB
 Dateiname: large_29870781_NEOt.jpg
 Dateigröße:  140.9 KB
meisner
Danke-Klicks: 225
Beitrag: 757827 Geschrieben: 18.07.2020 - 17:06 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
nice work - i like the yellow application on the handbrake leverbag... biggrin.gif
Opel ist wie LEGO!
meisner
Auto: calibra 2.5
Beitrag: 757830 Geschrieben: 18.07.2020 - 17:25 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
Thank you stego.
It was time to fix the wing brake light.
Since the last owner but led-is sequentially and the light was not bright enough.One led also was little dimmed then is changed everything.
I took the light appart and started working.
 Dateiname: large_29870831_3gel.jpg
 Dateigröße:  118.08 KB
 Dateiname: large_29870833_Z54x.jpg
 Dateigröße:  82.51 KB
 Dateiname: large_29870835_qNXk.jpg
 Dateigröße:  158.94 KB
 Dateiname: large_29870839_iBYb.jpg
 Dateigröße:  103.3 KB
meisner
meisner
Auto: calibra 2.5
Beitrag: 757890 Geschrieben: 23.07.2020 - 10:05 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
This time worked on the gear linkage.Gears wont go in like they should and is wobbeling to much.
I ordered new bushings set and let my friend to the the linkage off and change the bushings.It got better but still there is some problem with going in.
I also made a video about it so others car see how to change them.
https://www.youtube.com/watch?v=iVEskjcHp1M&t=229s
 Dateiname: large_29871155_5r0i.jpg
 Dateigröße:  110.35 KB
Danke-Klicks: 305
Beitrag: 757891 Geschrieben: 23.07.2020 - 10:34 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
Check the bearings of the shiftknob/lever. They get old and "wobbly" too biggrin.gif
Regards
meisner
Auto: calibra 2.5
Beitrag: 757892 Geschrieben: 23.07.2020 - 10:54 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
I checked the shift leaver and put new grease there,but thank you for the info🙂
meisner
Auto: calibra 2.5
Beitrag: 757920 Geschrieben: 26.07.2020 - 10:52 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
Phill thank you for the good words.
It was time to remove the clicking sound on the doors.There are plastic washers what wear out and under pressure they make the sound.
Also with the last job i found out that alternator belt has a crack and needs replacing.
There were 2 diffrent belts for 1997 calibra with AC so i took both and next wednesday my friend will change it.
I ordered new door washers from my local opel dealer.I ordered 3 sets because never know when they stop making them.
I also bought new transmission oil.When i checked the papers what came with the car the i saw that transmission oil was last changed in 2009 when calibra came to Estonia.
I hope that transmission is ok and oil change will solve the gear problem.
I will add some pictures
Alternator belt right now.
 Dateiname: large_29871311_QmO1.jpg
 Dateigröße:  91.8 KB
 Dateiname: large_29871315_7JVm.jpg
 Dateigröße:  74.99 KB
 Dateiname: large_29871317_0O2w.jpg
 Dateigröße:  61.67 KB
 Dateiname: large_29871319_t1oL.jpg
 Dateigröße:  85.4 KB
 Dateiname: large_29871321_hvsn.jpg
 Dateigröße:  88.8 KB
 Dateiname: large_29871323_gAwH.jpg
 Dateigröße:  79.52 KB
meisner
Danke-Klicks: 305
Beitrag: 757928 Geschrieben: 26.07.2020 - 12:14 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
I read about some guy who took the washers and replaced them with brass, selfmade on a lathe ja.gif i guess this option will work for our cars in the future. Keep going, it looks good so far.
Regards
meisner
Auto: calibra 2.5
Beitrag: 757930 Geschrieben: 26.07.2020 - 12:34 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
This is also an idea.I follow one english guy in youtube who just replaced them with 3d printed washers🙂I think as much i use my calibra they will last next 23 years before i have to change them😁
meisner
Auto: calibra 2.5
Beitrag: 758256 Geschrieben: 17.08.2020 - 17:56 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
Finaly i got the alternator belt and transmission oil changed.
With the alternator belt there werent any problems but with transmission it there was.
I dont know who previously changed the transmission oil but the bolts were tightened with brute force.
I had to buy new bolts because the old ones were tired.
I got new bolts from my local dealer.
Gear change got better but there is still a problem with first and second gear.
What should i look when first and second go in when clutch i pressed fully down.
There is no problem with other gears.
I will add some pictures also.
 Dateiname: 1.jpg
 Dateigröße:  59.93 KB
 Dateiname: 2.jpg
 Dateigröße:  85.22 KB
 Dateiname: 3.jpg
Alternator belt before.
 Dateigröße:  63.4 KB
 Dateiname: 4.jpg
New belt on
 Dateigröße:  64.91 KB
 Dateiname: 5.jpg
I also discovered that one engine cushion i worn out and they dont make it anymore.Thats why i have to get it custom made.
Looking the other cushions they are also worn out.This job is in the future.
 Dateigröße:  65.95 KB
 Dateiname: 6.jpg
New transmission bolt.I bought two of them for the drain and check.
 Dateigröße:  63.72 KB
 Dateiname: 7.jpg
Because the bolts didint come off then bigger tools were needed :D
 Dateigröße:  74.82 KB
 Dateiname: 8.jpg
Finaly got the oil flowing.
 Dateigröße:  106.63 KB
 Dateiname: 9.jpg
And always after maintance its time to clean the car.This time i cleaned the interior also.
 Dateigröße:  135.27 KB
 Dateiname: 10.jpg
 Dateigröße:  97.29 KB
 Dateiname: 11.jpg
 Dateigröße:  94.36 KB
 Dateiname: 12.jpg
 Dateigröße:  94.52 KB
 Dateiname: 13.jpg
 Dateigröße:  87.44 KB
meisner
Danke-Klicks: 225
Beitrag: 758258 Geschrieben: 17.08.2020 - 18:07 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
the problem with your first and second gear could actually caused by worn out synchronizer rings...
sadly there is no other way but to separate the gearbox from the engine, tear it apart and replace the rings with new ones...
but this might be a to complicated operation and a specializes workshop might want a lot of money for this...
another solution is to buy a second-hand gearbox and just replace the original... - but here at the risk that you don't know the state in which the 2nd gearbox is (it could also be worn out)...
Opel ist wie LEGO!
Calibra Koenig
Beitrag: 758262 Geschrieben: 18.08.2020 - 08:37 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
Schöne Idee so ein Kaufvideo.
Gab es den Keke auch in Grün? Dachte immer nur Weiß und Schwarz.
Danke-Klicks: 225
Beitrag: 758268 Geschrieben: 18.08.2020 - 16:18 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
er sagte doch das er es zusätzlich umgebaut hat - und ich glaube er versteht nur englisch...
@matze: ham wir eigentlich ne standardsprache im forum?
Opel ist wie LEGO!
meisner
Auto: calibra 2.5
Beitrag: 758270 Geschrieben: 18.08.2020 - 18:27 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
I thought also they were black and white but like this it came from Germany in 2009.
I have no problem when you speak in German.I can always use google translate😂
Wir hatten 412535307 Seitenklicks/Aufrufe seit unserem offiziellem Start am 10.05.2002
