Geschrieben: 03.03.2004 - 10:55 |
Hi!
Sorry, but I don't speak de. I'm from Hugary. I have a c20xe calibra. I have problems recently my car. The motor kontroll lamp is lighting often. The readout error code is 94. Hall sensor - voltage too high. Help me pls. It has come to my ear , that the lada samara hall sensor is selfsame. Do you tell me a serial number, part number etc.. to this Hall sensor? Where can I buy this? How much is it?
Thanks,
Ronaldo
Pls send me an e-mail : ronaldo@opel-calibra.hu ! |
Auto: Opel, Vectra A 2000 C20XE Auszeichnungen: 1
Geschrieben: 03.03.2004 - 12:03 |
Hi Ronaldo!!!!!
If you have the Code 94 in the control unit, you must change the Hall Sensor.
I can't say, if it's the sensor is the same from both cars.
Please controll the cable too! It could be that these have an interruption!!!!
If the cable is ok, than change the sensor.
You get this part from your GM-trader.
This afternoon, I'm going to go to the trader here in town, than I can say you the price...
GREET to Hungary!!!!!!!!
Ich hoff, man kann mein Englisch verstehen |
_________________ GREEZ
Chriss
...auf der Suche nach nem guten Zafira OPC |
Technik-Moderator
Danke-Klicks: 22
Geschrieben: 03.03.2004 - 12:22 |
The Hall Sensor is only for all Opel with 2.0i 16V (C20XE). You can get it at a Bosch workshop. Buy it never at Opel, because you can't get it seperate, only with ignition-distributor.
The Part-no of the Hall-sensor: 0 232 103 011 <--No. from Bosch.
It has kost in 2001 ca 45 € |
Geschrieben: 03.03.2004 - 14:46 |
thx, the answers!
Where is on the net this bosch sensor "0 232 103 011" I haven't found it with google. Is the hall sensor with ignition tower integrated, or can I buying only the hall sensor? How can I it exchange? Or go to service? |
Technik-Moderator
Danke-Klicks: 22
Geschrieben: 03.03.2004 - 16:33 |
You can get it seperate.
Here is the online-catalogue: http://fe0wap37.bosch.de/toc/en/BOY4QMN3W5MAXKRXPSLB42I.srv;jsessionid=0000BOY4QMN3W5MAXKRXPSLB42I:usru63kf?view=VIndexJsp
I wrote the instruction to do change the hall-sensor in german. The user Calimero01 can translate this better
Verteilerkappe und Verteilerläufer abbauen.
Verteiler vom Zylinderkopf entfernen.
Mitnehmerscheibe von der Verteilerwelle demontieren (Spannhülse austreiben). Wichtig Lage merken!
Dann kann die Verteilerwelle aus dem Gehäuse herausgezogen werden.
Jetzt ist der Hallsensor frei zugänglich und kann ausgetauscht werden. |
Geschrieben: 04.03.2004 - 09:13 |
Thx, I have found in the online bosch catalog.
An hungarian bosch worker wrote, that the Part No "1 237 031 288". I don't know. I can't find it on the online catalog. What is now?
Can you send me a photo from Hall sensor and the exchange? |
Auto: Opel Admiral A 2,6 Liter OHV Auszeichnungen: 2
Geschrieben: 05.03.2004 - 08:21 |
hat einer von Euch ein Foto vom Hallsensor für Ronaldo ?
Ronaldo,
find enclosed the translation of Michaels Instruction:
1. remove distributor head and distributor finger
2. remove distributor
3. remove friction disk
4. remove disributor shaft and then you will find the hall sensor |
_________________ Gruß
Calimero (Micha) |
Technik-Moderator
Danke-Klicks: 22
Geschrieben: 05.03.2004 - 18:45 |
Mitnehmerscheibe - friction disk
Position Mitnehmerscheibe zu Verteilerläufer - position friction disk to distributor finger
Blick auf die Verteilerwelle - view on the distributor shaft
Die Spannhülse, die die Mitnehmerscheibe hält - this pin hold the friction disk
Geschrieben: 05.03.2004 - 19:04 |
mann, technische Hilfe auch in anderen Sprachen, ich bin wirklich beeindruckt. |
Geschrieben: 08.03.2004 - 15:45 |
Hi!
I have going 300km the last weekend. I haven't flashing the motor kontroll lamp. The last lamp was 3 weeks. Is with the car is all ok? Or what is now? |
Geschrieben: 08.03.2004 - 15:58 |
Hi Ronaldo,
it can be possible that you had a issue in your system, that happened only one time. The System checks everything during the engine start and all the issues we only one time will be deleted after 30 starts.
So it looks like everything is o.k. at your engine. |
Calimero (Micha) |
