Adventskalender
Insgesamt 22632 registriert!
Gäste Online: 191
Insgesamt: 191 Fans!
Calibra-Team.de :: Thema anzeigen - V6 BiTurbo from Poland
Lenin
Beitrag: 205054 Geschrieben: 14.09.2006 - 21:38 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
Sorry for writing in english but i don't know deutch at all
I want to show you my Calibra V6 BiTurbo
We made it (with my brother and father) in our home garage.
We use:
2x KKK03 turbos (Audi S4 2.7 Bit)
modified stock exhaust manifolds
3'' exhaust with one 4'' silencer
we put 2 gaskets per head (comp. ratio is now 9.2:1)
346 ccm injectors (from C20LET)
Walbro 255lph fuel pump
second oil cooler
second water cooler
FMIC (1/3 IC from Renault Premium)
MAF from Supra TT
3'' intake
Perfect Power SMT6i to control fuel and boost
F28 gearbox (calibra is still FWD)
clutch from C20LET
light flywheel from C20LET
EGT,boost and oil pres. gauges
-40mm FK suspension
EBC greenstuff brake pads
we must remove A/C and move "alternator" :-\(?)
Totally cost is about 6 000pln (1 500 euro)
First Cali going on 0.3 bar of boost, now is about 0.6 bar
I make 6000km without ANY failure.
Pistons and rods are stock.
HP - ?
Nm - above 400Nm
best 1/4 mile ET: 13.520 (on veeeerry bad track)
0-60mph - image
The project isn't finish yet.
I already buy two X30XE engines and in couple of months we make a X30XE conversion and inrcease boost to 1 bar.
photo:
videos
http://www.eefoof.com/video/5362
http://www.eefoof.com/video/5367
http://www.youtube.com/watch?v=D3uhV7_5WvI
zottel83
Auto: opel Manta Corsa C30NE, C20XE
Beitrag: 205065 Geschrieben: 14.09.2006 - 22:07 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
absolut porno
where are you from?
DasBo
Auto: Corvette C5 5,7l V8
Beitrag: 205083 Geschrieben: 14.09.2006 - 23:33 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
WOW
will auch haben
Daniel_XT
Auto: astra g coupe z20let
Beitrag: 205089 Geschrieben: 15.09.2006 - 05:20 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
hätte dem wagen ja eher ne entrostungskur gegönnt so wie der vorne schon blüht
CLIFF-0057
Danke-Klicks: 9
Beitrag: 205117 Geschrieben: 15.09.2006 - 09:02 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
respekt.gif der sound ist ja mal richtig geil.
mit der leistung reisst der doch glatt stücke aus dem beton...
Calibaber
Beitrag: 205120 Geschrieben: 15.09.2006 - 09:12 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
michanie
Auto: Mercedes CLK320 3,2 V6
Beitrag: 205124 Geschrieben: 15.09.2006 - 09:59 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
Du solltest mal lieber einen preis hinschreiben ..... wenn ihr das bei einem machen würdet !!!!! Interesse hat!!!!
amicali
Auto: OPEL ASTRA GTC OPC
Beitrag: 205139 Geschrieben: 15.09.2006 - 11:08 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
0-200 km/h ca 16 sec respekt.gif
Lenin
Beitrag: 205141 Geschrieben: 15.09.2006 - 11:22 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
zottel83 hat folgendes geschrieben:
absolut porno
where are you from?
i am from Busko in Poland
doran
Auto: Calibra C20LET
Beitrag: 205146 Geschrieben: 15.09.2006 - 11:27 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
CLIFF-0057 hat folgendes geschrieben:
...Aber nicht mit 400 Nm!
Wenn er nicht auf Allrad Umbaut, ist es genau so sinnlos soetwas zu bauen, wie Tragflächen an nem 40 Tonner. Fliegen wird er eh nie können.
Geht nicht gibt es schon mal gar nicht! Das Einzige was nicht geht, ist ne Drehtür zuschmeißen!
http://www.LADEDRUCKBEFEUERT.de
MrArmageddon
Auto: Toyota Supra
Beitrag: 205193 Geschrieben: 15.09.2006 - 16:23 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
bei den beschleunigungswerten sollte der über 300ps haben. aber warum so wenig drehmoment? das selbe hab ich auch bei nur ~260ps.
have you ever did a dyno run?
Reendier
Danke-Klicks: 107
Beitrag: 205203 Geschrieben: 15.09.2006 - 17:16 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
Lenin hat folgendes geschrieben:
nicht schlecht, sieht zwar alles etwas gebastelt aus, vorallem die schweißnähte teilweise, aber 0,6 bar sind schon ne ansage. Bin mal gespannt wie lange das ganze noch hält mit 0,6 bar.
Fetten respekt.gif für das anpassen des des Ladedruckes und des Benzindrucks mit dem Perfect Power SMT6i....
ansonsten schön zu sehen das mal einer nen biturbo zum laufen bekommen hat...
@Lenin
which for a compression do you drive???
doran
Beitrag: 205205 Geschrieben: 15.09.2006 - 17:27 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
madbyte
Auto: OPEL Calibra Last Edtition 979 3.0 Liter V6
Spende (Anzahl: 1) Supporter (Anzahl: 5)
Beitrag: 205206 Geschrieben: 15.09.2006 - 17:37 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
But how you chane the Taxtime ? You don't drive with the orginal Motorcontroller Settings, or?
If I may ask: How much kost it?
Gruß Jörg
Mein Calibra
schrauber-scheune.de
doran
Beitrag: 205207 Geschrieben: 15.09.2006 - 17:39 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
Wieso sollte er die Steuerzeiten ändern?
Wir hatten 505574238 Seitenaufrufe seit unserem offiziellem Start am 10.05.2002
