Registriert heute: 2
Gäste Online: 329
Insgesamt: 329 Fans!
Calibra-Team.de :: Thema anzeigen - Opel Calibra Keke Rosberg V6 125 kw MY 1997
Snowwhite
Auto: Opel Calibra/Omega C25XE-Y32SE
Beitrag: 758429 Geschrieben: 06.09.2020 - 23:50 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
Did you also blocked the gearbox with the screwdriver as i do not see the picture?
meisner
Auto: calibra 2.5
Beitrag: 758430 Geschrieben: 07.09.2020 - 06:08 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
I just used the screwdriver to fix it to place when my friend adjusted it under the car. not the L key😁
meisner
Auto: calibra 2.5
Beitrag: 758547 Geschrieben: 16.09.2020 - 20:59 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
It was time to change the fuel pump because there were problems with starting.Fuel pump lid is quite rusty.I have to check maybe there is a change to use another car lid.Right now we put a rust stop on until we find another lid,because they dont make it to calibra anymore.
I also made a video how to change a Calibra Fuel Pump.
https://youtu.be/qbKnBwk1Kp4
meisner
Auto: calibra 2.5
Beitrag: 759024 Geschrieben: 01.11.2020 - 17:55 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
Its been a while since is wrote.
Calibra has still starting problems.
It wont start everytime.So my friend put the diagnostics on and no fault came out.
After that he checked fuel pressure and one problem came out.
Fuel preassure regulator was faulty.So i bought new one.
After that another problem started.Sometimes it wont start after 10 times when i try.
Friends said that maybe its fuel pump relay.So i bought this one new also laecheln.gif
I changed it and it got a little better but still there is a problem when there is a damp weather outside.
Here are couple of pictures.
Can anyone suggest a good online share website where i can upload new pictures and when i show them here
then pictures wont be huge size.In few days all my old pictures
will be gone from here because the service provider will be closed. laecheln.gif
 Dateiname: 1.jpg
 Dateigröße:  130.79 KB
 Dateiname: 2.jpg
 Dateigröße:  174.04 KB
 Dateiname: 3.jpg
 Dateigröße:  138.33 KB
 Dateiname: 4.jpg
After change fuel pressure stays at 3 bar.Before it just falled down.
 Dateigröße:  102.46 KB
 Dateiname: 5.jpg
Couple of pictures about the relay.
 Dateigröße:  131.76 KB
 Dateiname: 6.jpg
Old vs new.
 Dateigröße:  100.47 KB
 Dateiname: 7.jpg
Also cleaned drivers door switch and got it working again.
 Dateigröße:  81.69 KB
 Dateiname: 8.jpg
Also Santa brought spare rear springs :D
 Dateigröße:  120.6 KB
 Dateiname: 9.jpg
Also can anyone tell where can i find left and right not damaged side plastic trims
 Dateigröße:  111.45 KB
meisner
Danke-Klicks: 264
Beitrag: 759030 Geschrieben: 01.11.2020 - 22:07 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
meisner hat folgendes geschrieben:
then pictures wont be huge size.In few days all my old pictures will be gone from here because the service provider will be closed. laecheln.gif
Please use https://www.fotosverkleinern.de and load the pictures after resize here. Here we go with 5 MB each file. https://www.fotosverkleinern.de/ can limit this.
Choose "Größe des Bildes auf max. reduzieren" at 2,5 MB. I Safe your old pictures now in this thread and upload they in your post.
meisner
Auto: calibra 2.5
Beitrag: 759031 Geschrieben: 01.11.2020 - 22:15 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
Matze thank you for the info and many thanks about saving my old pictures.At least then history is safe😁Tommorow i will try to put pictures on my last post also.
Danke-Klicks: 264
Beitrag: 759032 Geschrieben: 01.11.2020 - 22:21 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
I takes many time, because your description is under every pic. please be patient. i can not fix all today.
meisner
Auto: calibra 2.5
Beitrag: 759034 Geschrieben: 02.11.2020 - 07:21 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
There are few days left before these pictures are gone,so you have time🙂Matze i have problems with that photo site.I uploaded photos there but when i try to look then its just loading and loading.Internet connection is 44mb per sek so its good.
Danke-Klicks: 264
Beitrag: 759054 Geschrieben: 03.11.2020 - 16:01 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
ok, try https://www.iloveimg.com/de/bild-komprimieren
Snowwhite
Beitrag: 759056 Geschrieben: 03.11.2020 - 16:25 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
Hi plenty of door strips here on brakeyards in Spain 😉
meisner
Auto: calibra 2.5
Beitrag: 759075 Geschrieben: 05.11.2020 - 20:18 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
I didint like that the center console heating part was dark,so i took the big job ahead and I dont want to do it anymore.😁
Before and After
 Dateiname: 1.jpg
 Dateigröße:  162.61 KB
 Dateiname: 2.jpg
 Dateigröße:  104.72 KB
 Dateiname: 3.jpg
 Dateigröße:  102.48 KB
meisner
Danke-Klicks: 305
Beitrag: 759076 Geschrieben: 05.11.2020 - 21:05 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
Fixing this thing can be a real pain in the ass biggrin.gif did it several times. Was not funny lol.gif
Btw: why don't you upload your pictures here on our site wiejetzt1.gif
Regards
Danke-Klicks: 264
Beitrag: 759077 Geschrieben: 05.11.2020 - 21:07 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
Please use the attachement for your pics!!!
this is the last time that i change your post.
meisner
Auto: calibra 2.5
Beitrag: 759079 Geschrieben: 05.11.2020 - 21:23 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
Ok matze.I will🙂
meisner
Auto: calibra 2.5
Beitrag: 759153 Geschrieben: 16.11.2020 - 16:59 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
Does anyone has or knows where can i get new blank key with opel logo and bulb place.Thats my primary key but like you see its broken.
 Dateiname: 34C68357-2A23-4AC4-B0C3-B03499A78A31.jpeg
 Dateigröße:  2.84 MB
Wir hatten 412053802 Seitenklicks/Aufrufe seit unserem offiziellem Start am 10.05.2002
