Insgesamt 22263 registriert!
Gäste Online: 139
Insgesamt: 143 Fans!
Calibra-Team.de :: Thema anzeigen - Opel Calibra Keke Rosberg V6 125 kw MY 1997
meisner
Auto: calibra 2.5
Beitrag: 761677 Geschrieben: 17.06.2021 - 19:02 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
Thank you some much.I got the front end fixed also.I am tryng to make a video about it and then i will share it here🙂🙂
[mod-edit: Title modified to "MY 1997". @meisner: you could have modified it by yourself, too, by just getting back to your first post, clicking the "edit" - button zwinkern.gif . Kind regards, T]
meisner
Auto: calibra 2.5
Beitrag: 761987 Geschrieben: 11.07.2021 - 20:41 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
After quite a while i made an update about my baby.
https://youtu.be/kj1sKnz0Vus
makro
Danke-Klicks: 6
Auto: Opel Calibra x25XE
Beitrag: 762073 Geschrieben: 19.07.2021 - 14:57 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
meisner
Auto: calibra 2.5
Beitrag: 762162 Geschrieben: 03.08.2021 - 16:45 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
I decided to put some pictures instead of video biggrin.gif .
I had a problem with starting like i told on the video.
I had my friend change it and after that my fuel tank vent valve problem went away.One time after the change engine light came on,but when i floored it,then it went away and its still ok.
Also when i got it changed the fuel consumption went down quite a bit.
ps.I dont know why it it showing picture upside down.When you click on it,then its right way.
 Dateiname: IMG_1992.JPG
 Dateigröße:  1.68 MB
meisner
Auto: calibra 2.5
Beitrag: 762225 Geschrieben: 13.08.2021 - 08:39 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
Help needed.I have problems with starting my baby.I have to crank it lot of times before it starts,and other times it starts right up.I did the paperclip test and got two faults.Nr61 fuel tank vent valve voltage low.I thought that problem is gone after i changed the valve,but seems not.Other code is 91,but i cant find what that is.Does anyone know maybe the camshaft sensor causes these problems?
Danke-Klicks: 72
Auto: Opel Calibra 2 NE, 2 V6
Beitrag: 762229 Geschrieben: 13.08.2021 - 20:16 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
91 oxygen Sensor, voltage too high (Lambda)
V
meisner
Auto: calibra 2.5
Beitrag: 762230 Geschrieben: 13.08.2021 - 20:47 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
What that means to high?I know when low its broken.
meisner
Auto: calibra 2.5
Beitrag: 762278 Geschrieben: 22.08.2021 - 17:29 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
A trip with my son and with my baby and also problems.
https://youtu.be/7QKpszP9E1A
meisner
Auto: calibra 2.5
Beitrag: 762707 Geschrieben: 21.10.2021 - 19:35 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
It was time to fix my baby,so i changed the crankshaft sensor and also made a video about it.
https://youtu.be/eYWDq3f6V8U
Also few pictures.
 Dateiname: 243100712_911848263099072_5621122899268281417_n.jpg
 Dateigröße:  349.12 KB
 Dateiname: 246863119_2933844670161093_3259502424875210730_n.jpg
 Dateigröße:  190.33 KB
 Dateiname: 247294460_885387378781028_6704644127619002463_n.jpg
 Dateigröße:  339.86 KB
AntHraX
Danke-Klicks: 17
Auto: C25XE
Beitrag: 762708 Geschrieben: 21.10.2021 - 21:03 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
Good to hear, the engine runs well. I had a similar problem some weeks ago, but my V6 didn´t start at all. Funny thing is, that you have the "expensive" sensor from opelteilekrause biggrin.gif which seems to work in your engine. With hat sensor my engine started, but didn´t run good and even died when in idle. I had to buy a genuine GM sensor for150€ and now it works perfectly. But I guess you have a X25XE? Mine is a C25XE and the former sensor even looked different. Funny that Opel even changed the screw that holds the sensor in place (E8 vs. allen screw) biggrin.gif In addition, I had to cut the wire of the sensor because it was below the oil cooler pipes and both socket and sensor were to big to get them out under pipes. After cutting the wire I found the broken isolation on the sensor. I guess due to heat from the oil cooler pipes for 25 years.
more here: https://www.instagram.com/nordkap.calibra/
 Dateiname: DSC08065~2.JPG
 Dateigröße:  218.44 KB
--> V6 <-- UPDATE Juli 2013
--> Spritmonitor <--
meisner
Auto: calibra 2.5
Beitrag: 762710 Geschrieben: 22.10.2021 - 05:58 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
Good to know that i am not the only one who had this kind a problem.Also like i mentioned in the video.When the wire was near the spark coil,then it had the same problems like your.Didnt idle good and finaly died.
Beitrag: 762717 Geschrieben: 22.10.2021 - 17:24 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
meisner hat folgendes geschrieben:
We had that issue with a X25XE Calibra ja.gif only an original sensor could fix it. We were lucky, there was a new one on ebay for sale.
Regards
meisner
Auto: calibra 2.5
Beitrag: 762718 Geschrieben: 22.10.2021 - 18:57 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
Good to know.Luckly i found the solution by moving the wire😁😁
meisner
Auto: calibra 2.5
Beitrag: 764335 Geschrieben: 06.06.2022 - 16:55 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
I'ts been a long time since i made a calibra video,but i wanted to share with you a new video.
Calibras new interior and how to change it
 Dateiname: 281293909_1200345737173115_6279770956001224296_n.jpg
 Dateigröße:  560.41 KB
Beitrag: 764336 Geschrieben: 06.06.2022 - 20:20 Antworten mit Zitat Sende EINEN Danke-Klick für diesen Beitrag Back to top
Yes, we alle been at this point biggrin.gif when I had my first Calibra, I changed from Mexiko to Black Leather interior. Of course I did some other upgrades, too ja.gif sometimes I really miss him traurig.gif
Regards
Wir hatten 422807019 Seitenklicks/Aufrufe seit unserem offiziellem Start am 10.05.2002
